Hi all,
I found loads of information about coverting any format to DVD. I have roughly 2,5 hours of material filmed on miniDV and oprimally I'd want all of that on one DVD. Probably not possible, since I wouldn't want to loose too much of the quality either. I have Adobe Premier and Pinnacle Studio (and some other sw) at my disposal, but the problem is I don't know in which format I want to capture the film from miniDV's for optimal conversion to DVD. Can anyone help? If there is a tutoria for this, and I just didn't find it, the link would be more than appreciated!
Otherwise, if someone could introduce a few alternatives and their pros and cons, that would get me started.
Thanks for your time and help!
Transfer in DV format over IEEE-1394. The result is first generation quality on the hard drive. Use DV format project settings. Edit that and then encode to MPeg2 for DVD @
9500+ Kb/s for ~1hr highest DVD quality
6500 Kb/s for ~90 min at medium quality
Forget 2.5 hrs if you want quality, 3800 VBR of you don't care. Or use dual layer DVD-9 and 7000 Kb/s for medium quality 2.5 hr.
https://www.videohelp.com/calc
Where can I find 1080p HD video that isn't .wmv format?
By brassplyer in forum Latest Video NewsReplies: 7Last Post: 28th Jan 2011, 16:36 -
How to find out , what format a dvd recording is..
By jcazel in forum Newbie / General discussionsReplies: 8Last Post: 10th Dec 2010, 15:01 -
HDV? MiniDV to PC? Format/Media/Equipment Suggestions!!!
By jamsoftheweek in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2010, 15:55 -
Best format for MiniDV convertion (Mpeg2 or H264)
By bisli29 in forum Video ConversionReplies: 6Last Post: 3rd Dec 2008, 04:49 -
miniDV to hard drive to miniDV while preserving time and date?
By vid83 in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 22:46
